1 - 6 of 6 Posts
So the SV1000s stock headlight assembly uses two h4 bulbs and I am looking to make a headlight out of two 18 watt led bars like these http://www.ebay.com/itm/2PCS-6INCH-...2858&clkid=9178770416931945036&_qi=RTM1562571. How would I wire this up for both on at all times? I tried using a wiring diagram but I am about as useful as a ferret when it comes to wiring.
Would anyone mind drawing up a simple diagram for me? Or point me to a thread I may have missed.
Wire both to the low beam and don't use the switch? Or you could tap into the switched 12v from the ignition switch. The lights will be on whenever the key is.
Or wire one LED bar for dip and the other for the main beam using the existing H4 wiring on the SV.
This is what I swapped onto my SV1000N
GSXR1000 K5~6 headlamp with a modified GSF600 flyscreen - works well
wire to the high beam and you will have a headlight kill switch. install a switch to kill the running light and you have a getaway bike.
1 - 6 of 6 Posts
