1 - 20 of 29 Posts
Discussion Starter #1
Newbie here. I just brought an old school 86 ninja 600R that was practically under water. Now that I road it for a couple of days i am going to spend the winter turning it into a "Custom Fighter". I will post the before, during and after as i go.
My biggest question right now is: What is my best option for installing a wider swing arm on that frame so i can mount a fatter tire on it?
Please don't tell me to get another bike. I am determined to turn this into something worthy to be on this site and for me ride with my special lady friend.
This is challenging because this old ninja doesn't seem to be customized often and i cant find many references.
Any help here will be greatly appreciated.
Cmon' Kitty!
First off: CF will never tell you to get another bike. We hack together 35 year old 100cc imports.
Second: I have the factory manual for your bike (I have a 1990 Ninja) best $35 I ever spent on the bike, period.
Third: Measure, measure, measure and remember that you can always machine stuff to fit
For inspiration you can look around at other guys with zx600 and zx500, they have similar frames and lines
Xtreet FighteX
I have a similar issue as the OP, although mine is for a 87 750r, similar beasts in nature.
In addition to this mod, beside swapping, are extensions an option for these aged bikes?
Fast ZX-12R
With some imagination almost anything is possible.
ill make it fit
you can do anything you want you can put a wider tire on but your not going to be able to get much more the 2 sizes bigger with out huge problems not saying it cant be dont cause it can. then if you do change the rear to a bigger tire. i would also go bigger in the front 2
Yut-Ughhh
I put a zx600e rear swingarm in my zx600c/r.....I just ground away 1/8" on each side of the frame, made bushings and pretty much said viola... it now runs a 160 tire.
ill make it fit
im just saying if you go bigger you may run in to the problem of lining up the sprockets with the tire being in the way
ill make it fit
i have been told to another bike
Yut-Ughhh
Measure and cross your fingers. Stock is a 130 on the lil ol ZX, and i got a 160 on it, and I could fit a 170 if I wanted to. Sprockets line up perfectly...everything is perfect.
Custom bikeporn addict.
Do you happen to remember what diameter the pivot bolt was on the ZX600C? Was it the same as the ZX600E or did you have to drill the frame?
I found the dimensions of the ZX600C. Looks like the swingarm pivot sleeve is 17.1MM x 25mm x 230MM. So that gives you some options for an easy swap. I'll have to take a look a what I have kicking around at home. See what might be close to start.
Thanks,
Bob
Fight the good fight
i have the same bike zx600r, 1986. running a 150 rear. looks like I could go bigger, but how big you wanting to go?
I just bought a 89 Ninja 600 c2 version and I am trying to make plans for the swing arm. Did you find an answer for a bigger swing arm?
What year CBR swing arm? What mods did you have to make? Any help you can provide would be greatly appreciated? Any pics so I can see what it would look like would be cool. Thanks
hi, im at the same point i think, want a bigger tire on my 89 gpz 600 r, i started to try and fit a cbr 600 1994rear wheel into the stock swinger but it just wont fit without the tyre rubbind.... so i have been offered a 1993 cbr donor bike for swinger but not sure how to go about it?
sam
sam
How big was that rear tire? I read somewhere on custom fighter that you can fit a 170 on stock for our bike.
complete asshole
it was a 160 rear... if the wheel was pushed forward in the swinger the tire was touching the outside of the swing arm. i suppose you could not push the wheel the entire way forward but i would rather just be sure you know?
i was toying with machining the part away as i think its only a brace section but i wasn't sure so i left it... i will try to get a pic.
1 - 20 of 29 Posts
