Also had a bit of a headache when one of the quick release fuel lines decided to break and pissed fuel everywhere
. As a result I've decided to simplify things between the tank and the carbs, get rid of the leaky fuel tap, and knock up something simpler and easier to remove with the tank, allowing you to keep the fuel shut off.
I'm going to run the 2 fuel lines from the bottom of the tank straight into a t piece and into 1 line, through a simple on/off shut off valve attached to the side of the bike, and straight into the fuel pump.
I'm also going to position the fuel filter so it can be seen easily without removing the tank, as the fuel pumps on these bikes are common to failure, so a visual indication of whether fuel is flowing is always useful.
Picked up a brass shut off valve, and replaced the o rings with fuel resistant Viton rings. Got a couple 1/4 bsp to 6mm banjos and soldered up some 90 degree bends on em so they angle up towards the fuel pipes.
Pretty pleased with the industrial look. Hopefully I'll get out to fit it to the bike soon.
Exhaust wrap should be arriving tomorrow, and the weather has now turned, so fingers crossed I'll get out to work on it asap!
