101 - 120 of 121 Posts
Hack in a barn
Discussion Starter · #103 ·
After an extensive period away from this bike; marriage, 3 changes of employment and 2 kids and a new garage, i finally dusted off the bike and reviewed where i had got...
Last time i rode it was about 3 years ago. I took it to work, which was 80 miles each way and to be honest that was the final nail for me. The handling was at best sh*t. Many years of mountain biking and DIY put my wrists in bits so the clip-ons, which whilst i preferred the look, had to go. Numerous other little niggles need sorting too, including a new rear end and subframe.
Best course of action - get hold of Lee at Steelheart Engineering who made the frame.
I explained the issues and sent him some photos and within a couple of minutes he told me the links were all set up wrong... Whoops! Stripped the bike down to frame and suspension ready for delivery and rectification.
Now, Steelheart are located in the south east of England way over to the west of London and i am in the west country. 175 miles each way to take frame, swingarm and front end so Lee could put it in the jig and sort my suspension links. This meant a trip up to drop off and then another to collect once all complete, 700 miles all told... Mmmm. Best thing in this situation, call on your mates. One mate lives just down the road and travels to London with work - sorted. Another mate lives 10 mins from Steelheart and goes to London for work. It was like destiny.
So a swap of beers for transport and the various parts are now with Steelheart.
Lee has mounted it all in the jig and identified what needs doing: New repositioned shock links brackets on lower frame. Cut out and fabricate new mount for top shock mount, incorporating the GSXR shock fork to allow ride height adjustment. He has confirmed, i was way out on angles. He is going to make good some other little niggles too, like the side stand bracket, lock stops and i'm sure there will be other things he spots.
Once i get the bike back, my list includes: flat bars, redo the wiring loom and strip out any unnecessary extra wires, sort headlight and clocks, new subframe and seat unit. I think i will swap the forks from the black GSXR 750 forks as existing to gold GSXR 600 forks (both K6) as i feel the gold suits the frame better. Whatever happens the main driver is getting a bike that handles properly and that i can enjoy, in relative comfort. The rest can follow on.
Don't expect rocket pace and hundreds of updates; as you can tell, things take a while round here.
I did have some up to date photos of the bike in its current guise that i was going to upload, but my phone fell out of my pocket a couple of days ago and got run over and absolutely mullered, so no recent shots exist. I'll update when i have my rolling chassis back or if Lee sends me any update photos...
Watch this space...patiently! 😁
Discussion Starter · #107 ·
Modified shock top mount to accept GSXR fork type attachment. It was originally set up to accept a R6 shock and it was incredibly difficult to get the bolt thru and then spanners on it. This way i now have ride height adjustment, easy access etc. Lower mount also modified to improve linkage rates. The swingarm will be cleaned off properly and scotchbrited. Looking at the pictures, i am going to have to remove those numbers and stamps too. They may be hidden once built up, but they are annoying me! May look to get it aquablasted to get into all small crevices at the back and remove all old paint. The swingarm has been modified to remove all hugger holes, the side profile holes etc. Ill get a better picture of the whole lot once i get it home. Shock also to be replaced once i find a suitable alternative. Various other smaller jobs have been done to improve the maintenance and overall.
Hood Automotive tire Automotive lighting Vehicle Motor vehicle
Discussion Starter · #108 ·
I haven't decided on the subframe or headlight yet, as i wanted to rebuild the bike first and then stand back and review.
I had an MT09 replica light on it, which may go back on, but i want to reduce the bulk around the front end. But i can also do that by losing the std clocks and going smaller. Less is more etc
Subframe was running a 2012 R6 tail, but it looks quite long and i think i would rather something shorter, akin to Yantosh's build, or maybe utilising an older style short tail like a XS unit. The other alternative was to have a naked sub frame out back
Discussion Starter · #111 ·
Waiting for my mate to collect all the parts and frame from Steelheart and then i'll arrange meeting up with my mate to get it home and then work can start
Discussion Starter · #113 ·
Frame collected.
Decided the SA looks a bit bulky with the infills done, so bought another standard arm and sent off to have aqua blasted back to alloy, to tie in with the frame better, as not keen on the black finish. Depending on the finish once blasted, i may polish some of the arm - not the cast part at the front. The new arm was cheap as the bobbin hanger had snapped off one side. I don't use them anyway, so cut both off, filed and sanded it flat (forgot to take photos). I use the lifters as fitted to the arm in the picture
Anyway photo of frame and arm:
Bicycle frame Bicycle tire Automotive tire Bicycle part Bicycle fork
Think i already said, but would like a replacement shock with better bounce characteristics, but this build is slow burn as have numerous other projects, children and stuff grabbing my time
wow...that's fookin beautious!
Discussion Starter · #117 ·
A belated update, as a new purchase hopefully remotivates progression of the build. With the new shock mounting/frame mods and bit of Swedish bump suppression we should be in a far more comfortable place than the previous incarnation / build. Ohlins TTX, loosely mounted:
Motor vehicle Machine tool Wood Gas Auto part
Wood Coil spring Gas Shock absorber Personal protective equipment
Motor vehicle Automotive exhaust Gas Machine Nut
I need to get the swingarm blasted. Just rung Reality Motorcycles and booked it in for this week. Progression, well better than last 8 months anyway!
Discussion Starter · #118 ·
Tire Wheel Fuel tank Vehicle Automotive fuel system
This a photo of a photo i took back when i first started building it years ago and it's what makes me want a stubby rear end/subframe, unbraced arm, gold forks and a lighter colour paintjob. The blue tank suits it much better than the grey. I keep looking at this for inspiration, so might as well share it
Looking at the photo makes me realise i want less hanging off the front end. I might use a cycle computer and number board or similar up front
Discussion Starter · #120 ·
I agree @yantosh and to be honest i would love to get an arm made for the bike. But first up i need to get it back on the road. I am really hoping that the suspension mods improve the ride quality. I will probably need to get the forks re-valved, but i am hoping the geometry is now correct. Before it was just not enjoyable to ride
