21 - 40 of 47 Posts
Hack in a barn
Never heard of these bikes untill now...
So it is a 850 parallel twin?
The trellis frame is a huge plus in the looks department, nice work so far can't wait to see where this goes.
Discussion Starter · #22 ·
I didn´t know myself Lara was riding a TRX850 until recently..
I got some serious stuff for the build incoming about 2 weeks
from US and UK.
Discussion Starter · #24 ·
Unpacked this today. R1 2003 forks.
They seemed a bit soft though, but that´s a later question.
With this buy I´ll get the colour I want right away.
Found out I still need a couple of parts to complete the front.
I hope I can use the R1 00-01 front wheel for the setup.
For certain I know I can use my bluespots and top/lower R1 00-01 yokes
with the custom made steering stem. What I not knew about before was that
this forks used a different front wheel axle then the 00-01 forks. Also, I need a
new fender that fits. Have to check with my local scrapyard on Monday.
If not, ebay has but it takes a lot of time getting it.
Discussion Starter · #26 ·
Sesame open up. 10,7 kg frame. Had a hard time this last 6 months get my hands
on one at reasonable costs. Thanks to Bubbaad, a fellow TRX forum member it was
reality. Thanks again Bubbaad if you read this. :)
It´s bought with an experimental thought. If it only had been to cut the frame
the original would have been enough. I´m gonna try to skip the big alloy frame part.
Get a look like the KTM/Ducatis lower frame parts. Cutting somewhere between the red stripes
in the pic. We´ll see later exactly where. It´s nice to have dreams, isn´t it? :D
Big alloy frame part.
Frame idea.
Bitches love Fighters
thats an ambitious idea. cant wait to see it come to life
Reactions: ROBBO
Discussion Starter · #28 ·
Not worked out the whole plan yet but yeah, it might be too ambitious for my skills.
My first problem already showed up, finding a really short rear shock <200mm.
All I know is that plans is changing fast and often when building, but thats fun too. :D
Discussion Starter · #29 ·
Time has really flown and I have been really busy.
I had a break in the Croftster build because I wanted a warm place to be
in when the winter comes. Last winter I lost all will to work when it
was -18 degree below zero in the workshop. Not any more though.
This is how it looked when I started out with the room in the barn.
This is how it looks right now. Electricity still to come.
I have a build thread for this as well if someone is interested in all
steps I did.
http://www.sporthoj.com/forum/showthread.php?258582-Mekverkstad
It´s a Swedish site but you can always use this translator.
http://babelfish.altavista.com/
The Croftster build is going again. :)
Started out with frame cutting.
Now, I´m collecting pieces of used steel from old frames.
Takes a while to make them clean but I don´t mind.
Hack in a barn
Just Here For The Party
You had to dig out the dirt floor! That's commitment!
Discussion Starter · #34 ·
Ok, first round of steel to use is cleaned and sandblasted.
Started mounting.
Using the old frame steel means I can´t afford a mistake.
To much work with it and I don´t have plenty of it.
So I made some paper templates to get a rough template
to transfer to the steel.
My grinder did the first cutting and then some manual filing.
I´m satisfied with the fit though it´s not perfect.
Almost done. Needs some reinforcement shells though.
Shells is inserted.
come back YAMI' were are you mate this is to good to mis out on fer sure :robssmilie:
Discussion Starter · #40 ·
Hi guys!
Thanks for being interested. It has gone some time and the build is on hold.
Mostly because of my TIG welding skills must be a lot better before I proceed.
Sorry for not keeping you updated. I just received some parts for the build
I´ve been looking for some time now though. It is going to be finished, that I
promise you. I will start again next spring welding or not being able welding myself.
I did renovate an old crappy XT600 this spring/early summer (no welding).
Before
After
This winters project is an old S10 that I will rebuild to look like a desert race bike.
I need it next season so I must do that first, sorry.
21 - 40 of 47 Posts
