1 - 11 of 11 Posts
Abministrator
Motorcycle Repair
This is the directory of all wBW articles on motorcycle repair and maintenance. It includes repair tips and information on installing motorcycle accessories, parts, lighting, brake lights, LED lights and more. The articles also review products for BMW motorcycles, Ducati motorcycles, Moto Guzzi motorcycles and Triumph motorcycles. However, this information is also useful for owners of any type or make of motorcycle.
87 Maintenance and Repair Articles and Counting!
Suspension and Steering NEW! Motorcycle chain adjustment basics
Installing Progressive Fork Springs on a BMW R65
More webBikeWorld motorcycle chain cleaning articles
Handlebar risers installation on a Moto Guzzi 1100 Sport (Convertibars)
Cleaning a motorcycle chain with Motul Chain Clean, Motorex Chain Clean 611 and kerosene; a comparison.
Raising the fork tubes changes the geometry of the motorcycle's front end and can quicken the steering.
Changing the Chain and Sprockets is a necessary maintenance task and there are many tips and tricks to consider.
Fork Oil Change article shows you how to perform this maintenance task.
Front Tire Installation is not that difficult, but here are a couple of tips here that can help make the job easier.
Progressive Suspension 420 shock absorber installation.
Converting high to low handlebars on a BMW K75 or K100 from the standard to the lower "C" bars.
Fork gaiters can extend the life of fork seals by preventing dirt and pitting on fork tubes.
Wheels and Tires Rod Neff's balancer is highly accurate, well-made and easy-to-use; you can do it yourself and save $$!
Motorcycle tire bead breaker costs less than $5.00 and works as well as anything we've tried.
Body and Paint Paintguard paint protection film is easy to install and can be reused.
Carbon fiber parts are relatively easy to make, believe it or not! This article shows you how.
Installing the SheerMask pre-cut paint protection film kit to protect your bike's paint and finish.
3M Scotchcal paint protection film can be purchased in bulk and cut to fit your motorcycle.
Rusted steel parts can be easily fixed with this special coating.
Bar End Mirrors installation article points out a few modifications and some more information on where to get the parts; it's based on Gary Gavin's great instructions on installing Napoleon bar end mirrors.
BMW K75 Low to High Seat Conversion with information on converting the "low rider" seat on a K75/100 to the standard height seat.
BMW K75 and K100 standard windscreen buffeting problems can be partially solved.
LED Lighting Hyper-Strips LED Accent lights can really show off your bike!
LED brake light or tail light complete conversion to replace the bulb with LED lights for ultra-visibility!
LED Bulb Replacement by LEDTronics: is it worth the cost?
LED Brake Light Bar by Signal Dynamics: installation information.
Flexible LED accent lights can be installed as auxiliary directionals or just for fun!
Super-Bright LED brake light bulb LED cluster can replace the standard 1157 brake/tail light bulb.
RiderLight LED Wireless brake light for helmets, saddlebags and more!
LED Wireless helmet brake light - the Signalfly unit fits on the back of a helmet!
Lighting, Brake Lights, Tail Lights Motorcycle Headlight Upgrade Ducati Designs upgrade for the BMW K1200LT.
Yellow headlight bulbs for motorcycles? Comparison with standard white H4 bulbs.
Install an HID motorcycle headlight for more power and visibility at night.
Install headlight protection film to protect expensive headlights from stone damage.
Ducati Designs headlight upgrade for ST2 and ST4.
Using turn signals as brake lights - good idea or not?
Brake Light/Tail Light Bulbs discusses the best light bulb to use for your combination brake/taillight. Covers 21/5W, 2057, 1034, 1157, 2397 and 2357 type bulbs.
Brake Light Flasher installation and review of the Comagination Visi-Stop.
Turn signal relay replacement on a BMW. Applicable to other makes.
Improving Brake Light Visibility how to brighten up your rear end!
Halogen brake light replacement bulb by DesignTech: Too hot to handle?
Headlight Modulators
Installing a Comagination dual headlight modulator and a modulator with solid-state headlight relay
Modulator Regulations for the U.S.A.; also the Canadian regulations in English and French.
Headlight modulator installation and review of the Comagination Visi-Path.
Kisan headlight modulator review and installation.
Brakes Bleeding motorcycle brakes is easy with this vacuum pump.
Harrison Billet Mini-6 brake caliper installation can improve braking.
Installing stainless steel brake lines can improve brake feel and performance.
Engine and Transmission Ducati engine case guard protects against damage from broken chains.
Bing carburetor replacement silicone gaskets last the life of the engine.
Oil change problems to avoid; oil types to use; sources for replacement oil drain plugs.
Air filter replacement can be easy or difficult, like on this Triumph!
Valve adjustment on a modern Triumph also has useful information for other makes.
Valve Adjustment Tips and some performance improvement tips from wBW Visitor "J.B."
Coolant Change - How to perform a coolant change.
BMW Airhead Spline Lube - 1986 BMW R65 Monoshock spline lube with photos.
Air injection system removal for post-1980 BMW Airheads.
Adjust Moto Guzzi valves with this step-by-step approach by Steve Saady.
Change the fuel filter on a Moto Guzzi V11 Bassa with this article by Rich Arimoto.
Electrical Install a speaker on a Garmin i3 or i5 GPS unit.
Posi-Lock connectors are a fantastic way to splice wires on your motorcycle! Purchase Posi-Lock connectors through webBikeWorld and help support the site plus donate to charity!
How to install a horn relay to get full power to those Freeway Blasters!
Installing a headlight relay can make your headlight burn brighter.
Sealed Batteries - Installing a WestCo sealed battery is easy! Instructions and photos
Electronic ignition module maintenance - applying heat sink compound.
Install a tachometer on a Moto Guzzi Jackal with instructions by Steve Saady.
Tires and Wheels Dymag carbon fiber wheels are light weight and expensive!
Portable motorcycle tire balancer is very accurate and can fit in a tank bag.
Motorcycle tire bead breaker - make your own in a matter of seconds!
Tire sizes can be confusing; read this interesting article regarding tire widths.
Motorcycle tire information on sizes, conversions between numbering systems, speed ratings and more.
Motorcycle tire and wheel balancing with Rod Neff's tire balancer
Miscellaneous Installing a Talon Motorcycle Alarm; includes information on adding a custom LED indicator light.
Make your own custom aluminum dashboard. Includes instructions and CAD drawings for download.
Motofx garage door opener opens your garage door when the high beams are flashed.
These valve caps are real metal with rubber gaskets! Sweet - and very inexpensive. Also information on where to find a metric thread pitch gauge
Here are some tips, gleaned from various email lists, on making repairs to ABS bags.
Here's how to make a small, lightweight air pump that can fit in your tankbag for less than $10.00!
Cleaning aluminum engine cases tips and tricks.
Interesting drawings from 1931 of an old "T" flathead side valve engine illustrating the four stroke engine cycle.
I shit awesomeness
good bump this should be a sticky
Go hard or go home
I read WBW regularly (or at least once every couple of weeks when the post a new story).
yea sticky this shit son
I shit awesomeness
this one thread alone will answer all the noob questions that we get cuz they dont know how to use the search function.
although we will still get the questions, but once we link them this thread. there should be no more from that user. if they do ask another dumb noob question... BAN HIM! :D
Reactions: daxabone
I bang metal
another vote for sticky
1 - 11 of 11 Posts
