1 - 5 of 5 Posts
Team Azzhole
Evening folks, I am currently doing a fork swap on my '01 Kat using a '98 TLS fork, all is good there. The problem is the guy who had the TLS before me drilled and tapped risers into the top triple for a 1" bar (and a home-made bar at that).
I want to replace the top triple and got searching around forums, etc and found sizing info on TLzone.net that says 99-07 Busa forks have the same geometry. With that in mind, could I just use a Busa top triple and clip-on bracket instead?
The reason I am throwing this out there is, I have found 2 different fork diameters for the TLS, TLzones chart is saying 50mm, but on other forum posts including here it says 52mm.
Could anyone firm this up, I have been searching for awhile now and keep coming up with 50mm and 52mm.
Here is a link to the chart on TLzone: http://www.tlzone.net/forums/suzuki-tl1000r-tl1000s-forum/95228-definative-fork-swap-chart.html
Thanks in advance :drinks:
1 - 5 of 5 Posts
