1 - 18 of 18 Posts
hi, looking on all your treads and bike i think to show you bike what i work on it. im near finishing it but i will show some pick of progres on it.
still need to make faring for headlight and finish brackets for side panels and some waterproof case for fuse box....
and 2 pick of difrent project from me xD
hope you like it :)
Psuedoiterative
Welcome Virhiryu. The paint looks great!
Love the table, what block is that?
thanks, table is from Jaguar XJ 5.3 - V12, still need to put electric motor in it to make it spin xD(any proposition what motor to use?) will put clip of it when will be finish.
fuckin genius
if you remove the piston rings, lube it good, any RC electic motor should do... could be wrong but if you remove most friction points..
fuckin genius
I almost feel bad for that v12... I feel like it belongs in an old chevy pickup ;)
hi, i have little question, becouse i try to fit today bulbs to me kawasaki z750 headlight but triumph is using h4 bulbs... and i dont know how to change the harnes from 3 pin bulb to 2 pin...
fuckin genius
whatever bulb your going to be using, go to the local autoparts store and grab a harness for that bulb, ground to ground and low beam power(from the 3 prong) to power of your 2 prong...
1 - 18 of 18 Posts
