221 - 236 of 236 Posts
I been fightin' gravity
Discussion Starter · #222 ·
built a carbon fiber heatshield for the battery. It rivits to the subframe. Pics tonight.
Fuel tank is just about ready for the top section. Got to get my damn air filter.
Got the fuel cap in yesterday.
Discussion Starter · #223 ·
here we go. Carbon and aluminum heat shield.
Bottom of fuel tank REALLY close to being done
That piece of wood is the mockup air filter. Now you can see how the airbox works
Discussion Starter · #226 ·
You may think i havent been doing anything, But you would be wrong.
Bike will be finished........
Havent posted pics cause my 2nd digital camera is now broken, WTF.
Discussion Starter · #227 ·
headlight is done, just needs paint. Its pretty dope
Got my epoxy resin and mold release today so Carbon Fiber bits in the near future
Discussion Starter · #229 ·
the bike is complete in that pic except for the seat. That pic was taken the day I hurt myself.
seat is done now, Its 4 layers carbon aluminum hybrid with a radiator air channel built in. Its stout
need to finish forkbraCE ANd tank and im done. also bleed clutch
Discussion Starter · #232 ·
1998 Honda VTR 1000 Superhawk
motor:
rebuild of top end
re hone
full port and polish
PAIR valve elimination, plugged Pair hole and flowed exhaust ports
removed Un Nessicary castings from both heads
Clearanced rear valve cover to fit Battery, modified crankcase breather
Hand made billitt aluminum Camshaft Chain Tensioners, red powdercoat
sanded block, removed extra castings
Cast coat iorn color engine enamel paint
New clutch friction plates
repaired and reinforced both stator and clutch cover
shortened, modified exhaust, 2 into 1, hand made muffler from c02 tank
Larger 5 row oil cooler, moved location, painted black
Oil cooler mount fabricated, drilled and tapped block for mounting
Carbs,
Jetted
breather removel
heater removal
1/6 turn throttle
1/8" alimunum baseplate for concept airbox
hand fabricated aluminum throttle cable mount
Ignition:
Twin Tech Hi performance Coils
Hand fabricated coil mounts
8mm plug wires
Cooling system,
Rear mount radiator
Dual fans, aluminum shroud
Aluminum 1" OD hardlines, dissipates more heat
welded mounts to radiator, capped and moved fittinngs
re mounted filler neck
modified water pump cover
Frame:
Sand Blasted, dents removed
removed front fairing mounting locations
drilled, welded, and tapped bungs for subframe forward mounts
hand built stainless fox shock resivour mount
Gsxr steering damper mount fabricated, welded to neck
Black bedliner
Subframe:
100% hand fabricated
3/4 inch OD 1/16 wall aluminum, gussited
alternative design, fit for single rear radiator
also locates and fits YTZ10 Battery
black bedliner
gunmetal color
Swingarm:
Sand blasted
Hand fabricated Bracing
Trellis design mimics main frame
3/4"OD 1/16" wall and 1" OD 1/8" wall aluminum tubing
black bedliner
Front forks:
Removed un nessicary castings-seams
Custom designed fork brace, 6061 T6 aluminum Billett
3 piece fabricated front fender, aluminum
black bedliner
wheels:
900rr front and rear
Brakes:
Front,
Honda RC51 reont Master cylinder, hand fabricated resivour reciever, Billet aluminum
Goodridge stainless steel braided lines, double banjo
Removed castings-seams from calipers, fully rebuilt
Red ceramic caliper paint, black accents
lightened front rotors
painted carriers gunmetal color
Small resivour
EBC HH Pads
Rear,
Honda RC 51 Master cylinder
hand fabricated Resivour adaptor
Goodridge line
Ducati twin piston Brembo Caliper, lighter and stronger
removed castings-seams, red ceramic paint, black accents
hand fabricated caliper adaptor plate, moves new caliper under swingarm
hand fabricated lever, ball bearing movement
small resivour, custom fabricated mount
Lightened rotor
Final Drive:
520 chain conversion, -1 +2
-1 JT front sprocket
+2 unknown rear sprocket, black powdercoat
520 x ring chain
Controls:
New Hayabusa Switches, throttle cables
Driven Meitor Cr low rise fatty bar, gunmetal color
100% hand fabricated rearsets, aluminum, adjustable 4"
hand fabricated GP shifter, aluminum, adjustable
hand fabricated brake lever mount
Lighting:
Hand built front headlight
Built from gsxr lower projector housing and clear cover, highly modified
Hand fabricated framework
Audi HID upper projector and ballast
Hand fabricated mounts and ballast mount
Tail light:
Upper LED tail-Brale light, flashing brake light
lower led running light
Fuel tank-Airbox HYBRID
Hand fabricated from 3003 grade alloy aluminum, 1/16 thickness, tig welded
Extensive use of english wheel
Fully baffeled, front to back, side to side
DESIGN CONCEPT, Teh tank doubles as the airbox. the bottom of the tank seals to a carb baseplate. This in turn moves the airbox higher and moves the heavy fuel lower, lowering the center of gravity.
K%N filter for Nissan Versa, modified
Carbon fiber intake scoop- rain guard
ducati vaccume fuel pump
billet aluminum filler cap, welded in
Seat:
4 layer carbon fiber, aluminum sheeting hybrid pan
Seat pan designed to channel air from top of radaitor,
heat shielding
memory foam
black gripper cover
Tail:
Hand fabricated carbon fiber louvers, to extract radiator heat
Aluminum mesh between louvers
1/16" aluminum sides and front, rivited to carbon center section
Aluminum mesh undertail to protect radiator from road debris
MISC:
Carbon fiber-aluminum battery tray-heat shield
Removed casting marks from triples
HIGHLY modified wiring harness, 1/2 stock weight
Moved all electronics up front behind steering neck
Modified Driven risers for further pull back
Brembo coffin style clutch MC
Black exhaust heat wrap
GSXR steering damper, Hand fabricated fork mount
COSTS
Steering damper, 15$
Bars, 100$
Brake parts, 125$
Aluminum sheet, 15$
Aluminum Tubing, 20$
Carbs, 50$
Carbon fiber resin, 50$
paint, 30$
Headlight, 10$ + 20$
tail light, 25$
fluids, 20$
fuel cap, 30$
misc, 200$
Total, UNder 1000$ including purchase
Finished weight, 348 lbs wet no gas. 376 full of gas
DRY 339 lbs
Future. Buell front wheel, rotor and caliper
RC 51 triples and forks
:scrapyard::shocker:
