61 - 80 of 93 Posts
Discussion Starter · #61 ·
Whacked together the rest of the arm, ish, the other day. Still going back and forth about adding a couple more tubes.
Motor vehicle Automotive tire Wood Gas Waste
Tire Automotive tire Bicycle tire Plant Motor vehicle
Got up the farm today and picked up hone kit / schlepped bottom end into parts washer, got washer running and had a bit of a scrub at it. Sprayed solvent through everything and washed all the junk from pulling the cylinders down into the pan; went down there to pull the pan and found clear silicone on everything, glad I got the full gasket kit.
Cleaned the pan out and peered around up her skirt while it was off, everything looks clean and OK.
Tomorrow likely I'll get to deglazing the cylinders and thinking about starting to put it all back together.
Discussion Starter · #65 ·
Painted the motor and started throwing it together the other day, after honing the cylinders and checking the ring end gaps
Tire Motor vehicle Automotive tire Wheel Bicycle tire
This setup worked well for the purpose
Automotive tire Motor vehicle Asphalt Road surface Gas
Plant Car Vehicle Automotive tire Motor vehicle
Oil pan will get pulled off next nice day and get some low glass black probably
Product Green Bicycle part Bicycle handlebar Safety glove
This HF hone was nicer than anything at AutoZone, advance, O'Reily etc, $22
Automotive tire Wood Rim Bicycle part Automotive wheel system
Worked fine, ten or fifteen seconds either way, had to really get some with the pumping motion to get a good angle.
Automotive tire Bicycle part Automotive engine gasket Rim Motor vehicle
The new style Rust-Oleum caps are perfect for a 66mm bore if you cut a couple of relief slits, saved me taking pistons off to square up rings in the bores for gap checks
Motor vehicle Automotive design Automotive tire Table Automotive exterior
I did two pistons at a time, used two 3" hose clamps to compress rings. No major issues
Automotive tire Motor vehicle Automotive design Auto part Automotive wheel system
I apparently didn't take any photos with the head and valve cover on so I'll get a couple and make another post soon
Discussion Starter · #67 ·
Motor vehicle Automotive tire Automotive design Engineering Gas
Font Badge Wood Metal Electric blue
Product Comfort Wood Flooring Floor
Motor vehicle Wood Automotive exterior Gas Cooking
Motor vehicle Automotive tire Gas Automotive design Engineering
More paint, and I whipped out these blockoff plates, cut the blanks on the table saw, screwed them to the stock valve caps and flush cut them.
Getting into finishing off the frame next so I can clean it up and slop some kind of coating on it. Leaning towards a basic bitch dark gray at the moment.
Fluid Drinkware Plastic bottle Water Bottle
Discussion Starter · #70 ·
Thought I made a post about this but either I didn't or my phone ate it. My brother came over for a few hours and helped me flop the motor over on its side. I also painted the frame somewhere in there
Tire Wheel Bicycle tire Bicycle handlebar Automotive tire
Pretty blue and light for a dark gray, but that's what the label said
Looks okay though, and done is good.
Motor vehicle Automotive tire Wood Automotive exterior Bumper
Tire Wheel Bicycle tire Crankset Automotive tire
Automotive tire Motor vehicle Hood Automotive lighting Electrical wiring
Tire Wheel Motor vehicle Automotive tire Tread
Discussion Starter · #72 ·
Due to my sweet pro status I'm able to access the VIP (vastly indignant personnel) area of Ivey industries, which is one of my favorite places to go because A) It ain't AirGas and B) Fuckin FREE STICKAS BUDDY
Finger Font Publication Art Illustration
They also had a clearance table and I snagged this thing for cheapo money. The counter dude even had to check to make sure it was priced right because we were both like "10$ for this??"
Publication Floor Line Font Flooring
Gonna be picking up them 7lb bolts and drillbits out of stuff with this mother
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
Authentic patina (this cart was stolen from MIT in the early 60s with an oscilliscope on top of it, and now that it's on the internet one of their fucking dog robots is gonna come after me)
Discussion Starter · #73 · (Edited)
While I was out trying to make time with Ivey, the bike sorted out getting itself down and putting its other shoe on, etc, which was nice
Tire Wheel Fuel tank Automotive fuel system Vehicle
I also discovered today that the upper head bearing outer race was installed by some guy with a hammer and not much of an eye, because it's cocked up about 3mm in a vaguely 4 o'clock direction in the cup... it is also cracked, predictably, which probably happened the first time they tightened down the preload nuts
So that's a $50 shit in my eye for the bearing and seals kit from All Balls but they also always gimme a damn sticker so rah rah
Automotive tire Hood Motor vehicle Automotive exterior Automotive lighting
Also noticed while cleaning this off that the stem is a Cognito item... must have cost more than the gixxxer front end, which in turn was worth more than the bike 🤣
Discussion Starter · #74 ·
I was able to acquire a rare billet skateboard and gleefully applied it to my cobblepot
Wheel Tire Fuel tank Vehicle Automotive fuel system
Tire Wheel Vehicle Automotive fuel system Automotive tire
I also drove 80 minutes so I could make a new alu bearing block for the rear end so I don't have to wait for the bearings that fit the one I already made to arrive... The fighter spirit buddy 😂
Still needs making in machine shop:
Spacer-jobber for the bar clamps to get them above fork caps and maybe move them back a little
Footpegs / rearset stuff
Caliper bracket needs modifying to suit the nissin rear
Rotor adapter
Discussion Starter · #76 ·
Automotive tire Leg Human body Dress Automotive lighting
The maxipad! What's the slogan, Always® With Wings?
Managed to jack up the first and last hole, spacing wise, when I laid out and drilled the stuff. At least I gang drilled them so the fuckups are evenly distributed in a smooth fuckup layer over the whole thing
Discussion Starter · #78 ·
Gold accents on motor fooking A+++++++++++++++++++++
Thanks for the feedback buddy any and all appreciated whether it's positive or telling me I'm an idiot for doing something (rex incoming)
I'm glad you like em, I was well pleased with the not-too-gold engine paint and the amount of it splashed around
Haven't managed to kick a big trench in it w/shit kicking boots yet either 🥾
Chugging along at a medium pace here, the next installment of Spectacle Theatre:
Tire Wheel Hood Automotive tire Tread
Laid out some more shit (more better this time) and drilled holes in all my parts to install rivnuts (unnnngh)
Tire Wheel Bicycle tire Automotive tire Motor vehicle
NUTS... of riv
Poked holes in the hatrack to take (unf) grommets even though they were a bit tight in the bore, so to speak
Tire Wheel Motor vehicle Automotive tire Vehicle
In the end as usual a bit of extra snugness was all to the good for everyone, as you see
Automotive tire Bumper Automotive design Wood Rim
Need to grab some washers, got 6mm ss allens to suit the rivnuts in a bowl somewhere here
#oldmanthings
61 - 80 of 93 Posts
