81 - 93 of 93 Posts
Discussion Starter · #90 ·
For an unintended side project you sure pulled out all the stops on this one 👍
You know how it is... They kinda tend to pull themselves.
We'll just not discuss the color-coordinated brake lines, kevlar plug wire sleeves and contrasting marine heat shrink that may or may not be coming 😇
Speaking of which, I got my new plug caps after I broke one, but I accidentally ordered non-resistor caps... So I got resistor plugs just in case the coils need them to trigger or whatever, sorted there.
I noted that the previous builder had somewhat shoddily filled in the NGK lettering with white paint so I did a somewhat neater job w/gold on the new ones, because goooooooold
Now it looks premium yo
Wheel Tire Land vehicle Vehicle Fuel tank
Discussion Starter · #93 · (Edited)
And beheld a pale rectangle
Wood Gesture Road surface Flooring Gas
Scritch scratch with the implements
Saw Wood Tool Workbench Gas
And then STAB! STAB! STAB!
Automotive tire Wood Engineering Gas Electrical wiring
This bit was molested in two separate locations. Well traveled, it is
Motor vehicle Toy Grass Engineering Gas
More ritualistic scribing
Motor vehicle Grass Gas Bumper Font
More stabbing is needed here
Engineering Electrical wiring Circuit component Electronic engineering Slip joint pliers
Oooo lookit, purpose
Tire Wheel Cabinetry Automotive tire Automotive lighting
Lovely. Note to self: Replace sheet metal screws holding part in place with real bolts, you know, sometime
Tire Fuel tank Vehicle Automotive lighting Wheel
81 - 93 of 93 Posts
