1 - 5 of 5 Posts
about to buy some stainless steel sheet to build a bolt on under tray for my tracker . will be a sheet with a single 30ish degree bend at the back and all it will be for is to bolt the cdi and reg rec to under the seat...what thickness metal do people use for their under trays???
i am thinking 1.2mm but thought id get other peoples opinions before i waste 30quid on metal that is too thick/thin
Super Moderator
2mm stainless is really hard, nearly impossible to make proper bends without a big bench. I`d reckon 1,2mm will hold your battery nicely, if you doubt make a 90 degree ~10mm strenghtening bend at the other end, that shoud stifen it right up.
Cmon' Kitty!
I've gotten away with 1mm aluminum, using a lithium battery. Cheap and light.
1 - 5 of 5 Posts
