1 - 4 of 4 Posts
lb/hp is what it's about!
With your gsxr being as new as it is you probably won't find anyone with first hand experiance doing this swap with that exact bike. I know there is a sticky thread somewhere on the forums with all the different VFR sssa dimensions but I'm not sure where exactly. I think there is a suspension swap subforum so I'd check there first.
Best place to start is measuring your swingarm pivot width and checking the vfr widths to see where you stand. If it's close and you can remove a little here or a little there and maybe get away with swapping bearings or making a spacer tube that will be half the battle. Once it's bolted on you'll have to deal with the suspension. That is where things get tricky.
1 - 4 of 4 Posts
