61 - 75 of 75 Posts
Discussion Starter · #62 ·
Automotive tire Wood Natural material Auto part Flooring
Wood Bedrock Metal Fashion accessory Glove
Wood Bedrock Concrete Rock Soil
Helmet Automotive tire Sculpture Art Gas
Lot of thrashing & elbow went in, at one point i was seconds away from throwing in the towel & pulling a negative in fibre
Discussion Starter · #64 ·
Automotive tire Automotive lighting Motor vehicle Fender Automotive exterior
Stitched into the bottom, the pump will sit horizontally under.
Discussion Starter · #67 ·
After a first round of grinding out the surface, it started to look like it belongs
Wheel Tire Car Land vehicle Plant
Tire Wheel Car Land vehicle Motor vehicle
Tire Wheel Land vehicle Plant Vehicle
Wheel Tire Car Land vehicle Vehicle
Plant Tire Wheel Automotive tire Flowerpot
Discussion Starter · #68 ·
I'm going for a complete buff to a polished finished to eliminate any irregularities with the surface, once the mirror finish checks out, will close in on what parts of the tank need a brushed finish/ masking to incorporate colours etc.
Using a Harley cap that has 0% iron in it. The cap's top section is removable with the pull of a ring lock, intent is to create a custom cap with the Harley's threaded cap body
Hand Camera lens Wood Cameras & optics Point-and-shoot camera
Automotive tire Gas Camera accessory Rim Bicycle part
Had the outer threads milled, welded into the tank already
Discussion Starter · #69 · (Edited)
Passive circuit component Circuit component Green Hardware programmer Electronic component
Motor vehicle Automotive tire Automotive design Hood Vehicle door
Had taken apart the stock panel to separate the motherboard from its LEDs, create a separate console for them, dislodge the LCD panel from the motherboard & have it sit separately with an independent third tiny rpm digital gauge. Considering the lcd was hard wired into the board, i went the other route of mating the gauge near the tree & have it appear minimalistic. Will share pics when I get there. The bike's heavy dependency on this motherboard won't allow for an independent aftermarket setup so not going to mess with this one.
Product Mobile phone Telephony Communication Device Gadget
Discussion Starter · #70 · (Edited)
Eyewear Vision care Bag Wood Personal protective equipment
Recreating the seal wasn't the sweetest job, on a double check, some areas needed a second fill. Sorted & secured.
I should have the tank bolted to the chassis in a week's time. Some imperfections appeared after the buff & polish, fixed mostly, its ready for mounting points.
Will pull the sub frame next & start with moulding the seat pan, sub frame. Exhaust system from there. Can't wait to get on with it.
Been away long but longed to post here every other day, work just wasn't getting done fast enough.
Good to be back & grt to see the old hats still here & going strong
Cheers guys 🍻
Duuuuude Vik`s back!!!! Keep at it mate always keen to see what you come up with! Stellar work with that tank, pretty sure I wouldn`t trust myself enough to even attempt that.
Reactions: Vikrant Singh
Discussion Starter · #75 ·
Yantosh Shiny Bandit & Mattson ❤
Heartening thoughts guys
Will attempt to complete the build within a quarter, should hopefully get this thread loaded with plenty ovr the next months.
61 - 75 of 75 Posts
