1 - 11 of 11 Posts
That just happened
That just happened
Ha oh by no means am I looking at buying this cheap piece of plastic, I'm just baffled by it. Because technically that would work if it was done correctly and not made in china
fatass needs corndogs
Hahahahaha! Im getting one for my lawnmower. Lol
My uncle dabbles with lawnmower pulling tractor contraptions and has used stuff like this. Last build I heard about he was running a pressurized propane tank with a huge regulator hooked to the throttle feeding a zx6 motor. He said these are good for 2-3 pounds and about a week...pure shit
not Gunna lie. always thought of trying to put one of those on a little 50 or somthn.
We had this little 70cc chinese pit-bike hanging around when I worked at the marina, not really sure where it came from. Anyway it was our target for experimentation and settling arguments about if something would work or not. We rigged a marine bilge blower fan to the airbox to "turbo" it.
After a while of fiddling with the carb and drilling out the main jet a little, and making the fan a push-button activate, we actually kind of succeeded. Due to how the carb was now set it would run okay-ish up to the midrange without the fan. You'd have to simultaneously snap it WOT and press the button to turn on the fan, which would give you a mild but noticeable boost in power for a limited RPM range, once it revved out too far I think it was going lean again and would fall on it's face. Still, a "proof of concept"
1 - 11 of 11 Posts
