1 - 3 of 3 Posts
2003 Suzuki SV1000s
Everything is basically stock up to this point but I want to get a PC and exhaust. I have a 2003 sv1000s. My main concern is that it has 36000 miles. Will the rings and valves ect withstand a few more horses. This winter I want to tear her down and put new rings get the valves done and whatever else anyone can suggest. Any suggestions would be greatly appreciated
Super Moderator
If it were me, before I go and spend the money and time on what may be an unnecessary rebuild, I’d do a valve adjust and then a leak-down test. The leak-down will give you a clue to ring sealing, etc. If you have minimal leak down, you’re wasting your money, IMO.
If you want more power than a PC and full exhaust can give you then better camshafts (if available) would be my next step. They’ll help the engine breathe a bit better and are minimally invasive. If you want even more than cams alone can give, then head porting and higher CR pistons would be the next stage.
Later, Doug
1 - 3 of 3 Posts
