1 - 8 of 8 Posts
I'm fitting an R1 caliper to an FZR400 rear end as part of my project.
I'm in the process of lining it all up on templates etc to get all my final measurements and possibly a model made up to supply to my local machine shop.
As its a brake part I'm keen to make sure it stays in one piece and is there when I want/need it.
So simple/stupid question - what grade aluminium do I get it made from?
Cheers
Super Moderator
What grade "Billet" do I use
6061 is pretty common for brake caliper adapters but 7075 might also be a decent choice.
I made a bracket to fit a Brembo rear caliper, from a Ducati, to a Vfr swingarm from 5/8" thick 6061.
Later, Doug
lɐʇuǝɯᴉɹǝdx&#4
Re: What grade "Billet" do I use
I'm a big fan of 7075 for manual machining. Extra strength is a bonus, especially when threading, and its no harder to work. But i buy cutoffs at $5 a pound or less. New stock can be insane. Unless i already have suitable 6061, I'm using 7075 for my caliper mounts.
I would also get a T6 no matter what alu you're going to use, cause of the elevated temp in the area.
Also note that the 7000 series of aluminium corrodes more than the 6000 series. (would recommend painting the 7075)
True on the corrosion problems with 7075. Especially if its in contact with raw steel. Shit goes crazy.
galvanic corrosion is like a :ninja:, fast and you don't see it coming before its too late...
Thanks for the advice all. I've gotta finalise the measurements before I go see the machinist but at least now I've got half a clue what I'm talking about and don't end up with a piece made of cheese.
1 - 8 of 8 Posts
