1 - 11 of 11 Posts
I'm looking for the easiest plastic to make my under tail fairing. I know most people say ABS, but ABS is really hard to work with. I know there is thinner and more moldable plastics out there. Does anyone have any suggestions?
Elbow Grease is Cheap
Edit: go make an introduction with more pics, a bit about yourself, where you're from, yadda, yadda......
I recall someone using PVC pipe. Cutting it lengthwise, then heating it to make it flat. cut to desired shape, the heat it again and form it to the mold.
I bang metal
your best bet will be to make a plug or buck and then form it to that
Will have a bike... soon
PVC would work. I use it a lot for the crafting stuff I do for cosplay props. However, you do not need to buy it in pipe form - you can get sheet PVC in various thicknesses from places that make outdoor advertisements and signs. Just google "PVC sheet in ________" (insert your city name) and you should find it. All you need to work with PVC is a heat gun and a Stanley knife.
1 - 11 of 11 Posts
