1 - 20 of 43 Posts
anything you wash a car with....along with wax
wd-40 is good for getting all the grime off your wheels, chain, sprockets etc....
for touch ups i use a california car washer and Pro Honda polish/cleaner
· Eff Tee Pee
+1 HONDA POLISH IS THE BEST!
· Eff Tee Pee
if by "jet" you mean a pressure washer..then yes, be careful. those things will not only peel off decals, but also they can disconnect electrical shit and/or put holes in rubber hoses. so be careful of that.
· Eff Tee Pee
The Green Lantern said:
pinesol works good to if you want a lemon fresh smeeling bike
speaking of scented bikes has anyone heard of the fuel additives that make your exhaust smell like cherries and other fruits?
· Eff Tee Pee
ab420 said:
I've heard of that, but I've never seen.... er... smelled them in person!
im tryin to find a link. its probably one of the stupidest things i've ever seen.
its called cherry bomb i thinks.
· Eff Tee Pee
you tryin to clean your bike or blow it up?
its not for either. :LolLolLolLol: it makes your exhaust fumes smell like cherries?!
:squid: :squid: :squid: :squid: :squid: :squid:
· Eff Tee Pee
hahhaa. yah. totally fuckin pointless.
· www.FirstPlaceOils.com
and gets water in your head lights ect...My swing arm got bout a quart of water in it, corroded the chain adjustment bolt, it broke off,then when drilling it out found the water had to drill another hole in it on the bottom or it would of froze and been bad!
· Eff Tee Pee
wait...you put a hole in your swingarm with the pressure washer, and it filled up with water???
or you washed it, water got up in there, it sat, then rusted??
:vshock:
· Eff Tee Pee
^ thats exactly why i never wash my bike ^
1 - 20 of 43 Posts
