1 - 3 of 3 Posts
fighterer still learning
Im looking to change my metal clutch master cylinder on my vfr750 to a radial master that uses the pot for the fluid instead.......
but im a bit confused as my 96 vfr750 clutch master has a 6 an A and a big 1 cast into it
but ive just found this info on the net:
Clutch system:
Clutch master cylinder I.D. 14.000mm (0.5512 in.) (9/16")
Clutch slave cylinder I.D. 35.700mm (1.4055 in.)
so is my master cylinder a 1" bore or 14mm???? trying to swap it out as its the ugly metal type...........
Wat bikes use the pot type master cylinder that would be the same size as mine?
Thanks for any helps guys!! :D
Busa Uses a 14mm
1 - 3 of 3 Posts
