GS750 First fighter build
Hey guys, and gals. The names MO! I've been building this 1982 Suzuki GS750, and during the build I googled somethings (questions and what not) and got directed to this page a few times, so I decided to sign up and share my bike and see if I can help anyone, or anyone can help me. I'm a noob to this forum so take it easy on me. Bring lube.
That's what the bike looked like when I first got it . I learned how to ride on that bike haha. But anyway.
Had it for a while me and my brother messed around with it. We made it into a hard tail at first, we got rid of the side shocks/spring whatever. And messed with the handle bars .
Then we decided to chop the rear off and get a bobber look . and got a straight drag bar .
Rode it like that for a while it was a really fun ride . then when winter hit I found a deal for a rear swing arm, front and rear wheel, and a rear caliper assembly. so I bought that, then took the bike apart and started test fitting to see what I had to do. The rear was off of a yzf600r 1998 (if I remember correctly )
The front wheel was too big (obviously) for the front forks/triple tree assembly .
I later got the rear shock assembly for the swing arm. I also got a 89 GSXR front end almost complete just missing top clamp and handle bars. (which I later got)
(There is a lot of pics and things that were done . can't do it all in one sitting lol, fforgive me . if you wanna see more just holler. )
:rock:
Alright, adding in some more of the build. I'm near the end. I can see the light.
Here, as you can see, I'm getting the front end and harness ran through and figuring out what I'm gonna use. And what I'm not .
(excuse the mess)
I later had to cut the bar you see there to get the swing arm to clear.
After that , I figured out chain clearance, ground clearance, and height. Then made a mount for the top of the shock.
(this is a little mock up )
(these are from before I tack welded.)
I'll get more posed asap
I later tack welded that into place. After I tack welded I double checked everything tested the tack welds with the bikes weight. Plus mine (220 pounds )
And they held in place. And it did what it was suppose to do.
I also had to make a mount for the rear brake master.
Hope I'm not boring anyone haha but after that I welded everything into place .
As you can see , the tail end is too close to the wheel. Plus I want to get some height on the tail. So what I did was heat the tubes and slowly lowered the bike onto a piece of wood.
After I raised the rear I set the tank on and and the seat to figure out how I want to mount the seat.
It's coming together pretty nicely , I'll have to post the rest later but if you have any questions or comments. Feel free.
** Hey guys so I ran into a problem with the chain alignment. So I went to the help section. And figured out what I need to do. I ordered a 5/8 offset sprocket. And everything is good except the bottom chain / frame clearance.
So now I'm in the works. I have to take everything back off and cut to make clearance.
This was the previous gap!
The sprocket.
gap be gone.
Any recommendations?
:rock:
(excuse the mess)
The sprocket.
gap be gone.
