1 - 3 of 3 Posts
Gsxr Power 1371
hi all
i have a gsxr 1100 oil cooled (1371) which i want run gsxr 1000 K1 wheels what is evolved to make this work i want keep my forks but i am running 320 discs and spondon adjustable calipers so i assume spacers what about bearings etc and spindle on the rear i am running a stretched jmc
G
Problems are......
different sized spindles & bearings
wheel hubs different widths so clearance & disk/sprocket spacing could be an issue
Disc offset different as above
possable chain run issues if you want to go 190/200 on the rear
your current discs/calipers may not fit
A complete front end off the K1 would sort the front with a stem swap & then all you have to deal with is the rear
Good luck
Gsxr Power 1371
hi thanks for reply this what was thinking on front would be bearing swap unless gsxr 1000 spindle same length and thread if not then then bearing swap gsxr 1100 into the gsxr 1000 front wheel and crush tube and then main issue will be making the spacers up and caliper same adain as its a spondon on bracket with spacers prob just spacers on there too
rear is running jmc drag arm on my gsxr 1100 i heard take and shim 5mm off sprocket carrier and sprocket carrier spacer then use gsxr 1000 spindle and make spacers up
just want make sure this all right so i know will work out ok
1 - 3 of 3 Posts
