1 - 5 of 5 Posts
I am going to have a look at a 1990 GSXR 750L this weekend, i have a K1 GSXR 1000 swingarm in the garage and i am just wondering if it will fit or how much will need to be done to make it fit, i am guessing that it has been done before so hopefully someone can help.
Jarhead Supreme
I would guess it can be made to fit with enough engineering. The first thing I would do is get measurements of the width of both swingarms at the pivot, or where the swingarm fits into the frame. IF they are close, it may work.
Super Moderator
I believe it fits in just fine with the correct pivot spacers but getting the linkage to work properly is another issue. Someone somewhere (in Europe, I think) was making a special lower mount to use the newer linkage and get the right geometry.
Later, Doug
Reactions: thaOrleanyte
Later, Doug
I need to find this person, i now have the complete rear end to fit.
watches you sleep.
I think this is another case where you need 20mm to 25mm spacers for the pivot bolt. Also the sprocket alignment I believe is off. From what Ive been reading you can get about 85% of it all done by mixing and matching parts from both rear ends.
1 - 5 of 5 Posts
