Alright, someone else mentioned that there are a lot of cats on here who would be interested in running wire wheels on their bikes, but there's a lack of availability for parts to do so.
I concur, there definitely is. About the only off the shelf option would be to get a Ducati Sport Classic hub set, and run them.
Of course, you'd need a second mortgage to do that.
So, like everything else, sometimes you just gotta make shit.
Here's MY way to tackle this problem.
WHAT YOU NEED:
1) Good math skills for finite measurements
2) Machining ability (or a damn good machinist who gives you a deal)
3) Classic Japanese/European hubs
4) New rims/spokes
5) Tires..
I've got *most* of this done, it's still a work in progress (we just had a baby boy a month ago, so things have moved a bit slower than before. lol) but I'll try to get all bases covered.
So here we go.
STEP ONE: PREPARING YOUR HUBS THEMSELVES!
If you want to run vintage hubs you're gonna need to run modern bearings.
Obviously modern axles are a larger diameter than vintage ones.
The example I'm using from my own bike is a KZ650 front hub. The forks are 2002 GSXR 600 front forks.
I took the measurements and found that the bearings needed for the gixxer axles need to be 25mm ID.
A looksie in a book at work showed me that the smallest SAFE 25mm ID bearing to run has an OD of 47mm, and a thickness of 12mm. There was one that was 43mm OD with a 9mm thickness, but that's a bit thin for something like this.
A GREAT place to get the bearings you need for this project is VXD Bearing Supply. I'll link you guys at the end here.
So, order up some bearings.
Then you'll need to measure the bore of the bearing cups on the sides of the hubs. I don't recall what the bore was in the KZ before the work, but I *think* it was around 35mm.
Sandblast your hub before you machine it, or send it to a machinist. It makes things MUCH easier to see, scribelines easier to follow, etc.
Basically, it's like boring a cylinder for a big bore kit.
You're gonna take off enough to accept the OD of the NEW bearings. In my case, 47mm. NOTE: YOU WANT A TIGHT FIT IN THERE. THIS SHOULD OBVIOUSLY NEED A PRESS TO INSTALL THE BEARINGS!
STEP TWO: SPACERS FOR THE HUBS TO CENTER THEM IN THE FORKS!
Okay, so now your hubs will mount the axle... but they're too god damned skinny!
Design some spacers to center them.
This is one place where a LOT of math will be involved, becuase it's likely that you'll need to take more off of one bearing cup than the other, so you'll need to compensate for that.
If anyone has any questions about the math to get this one, send me a PM. It's a PITA to explain.
After my math, this is what I come up with though:
PRINT EDITED OUT OF POST. CONTACT ME FOR INFO!!!
The OD of the main spacer there is the mated ID of the oil seal that will be over the bearings... the OD of the larger portion of the spacers is the same as the OD of the bearing cups in the hubs, so it will "seal in" the seal/bearing combo. The ID of the spacers is matching the axle.
The length was calculated to center the hub in the fork perfectly.
STEP THREE: SO NOW MY HUB IS ON MY AXLE, AND IT'S CENTERED, BUT MY ROTORS WON'T WORK...
BIG time machining for this one.
You need to calculate the thickness for a spacer/adapter. I call it both because it serves two purposes....
1) It spaces the rotors OUT to line them up with the calipers... and
2) It adapts the bolt pattern since there is NO 320mm floating rotor with a vintage Japanese 4 bolt pattern (Outside of Klasmos kit, that is like $500.00.)
Math is important here, because you need to calculate all this stuff.
It helps to have a stock bike with the same forks in front of you to use for one calculation.
You need to know the distance between the insides of the rotors from one to the other. We'll call this "X".
You also need to know the distance from one mounting fact on your hub to the other. We'll call this "Y".
Then lastly, you need to do the math.
X-Y/2=SPACE PER SIDE.
Let's say X is 100mm. Call Y 64mm. That leaves you with 36mm of space. Divide that in half since you need 2 sides, and you get 17mm per side.
So, your spacers need to be 17mm IF YOU ARE RUNNING A 0 OFFSET ROTOR!!!
If you are running a rotor without a 0 offset (which is likely) you simply subtract the rotors offset from the spacing.
(17mm- ROTORS OFFSET= corrected spacer thickness.)
So that takes care of the spacing of the rotor. But what about the mounting?
You'll need to adapt the pattern. In the spacer manufacture you will set it up so that the adapter/spacer mounts to the hub with countersunk allen head cap screws (I recommend stainless), and you want to have a "new" pattern drilled and threaded to mount your rotors.
Again though, MATH! Some of the old 4 bolt patterns won't work with a modern 5 bolt adaptation because some of the bolt holes overlap.
Also, the adapter should have a lip on the outside that is "rotorcentric" which means the rotor has a lip that it can slide onto before bolting on to ensure centering.
Here's my plans for the adapter/spacers:
This is what the finished adapters look like:
Now you mount these to the hubs, and everything will line up (assuming the math was right.)
These were made of 6061-T6 aluminum. They weigh less than 1 pound per side. They are so close to the axis of rotation that the weight shouldn't make a difference even if it is slightly more.
(***You will likely need to mount these to the hubs with FINE THREAD metric all heads. These can be a real bitch to find, and when you do places will try to charge you $7.00 a pop! DON'T GO FOR IT! Go to your local honda dealer and give them the part number you can find on http://www.ronayers.com for the correct HONDA SPECIFIC allen bolt. Unlike other manufacturers, HONDA lists measurements of MOST bolts on their microfiche.
IF YOU ARE IN THE UK THIS WON'T BE A PROBLEM CAUSE YOU LIMEYS CAN GET UFC METRIC EVERYWHERE. haha)
STEP FOUR: LACE UP SOME FUCKIN RAD WHEELS....
These are 17's, 3.5 and 5.5 Excel Takasagos from Buchanan. They've been mediablasted now to get powdercoated, but this was the day they showed up at the shop I work at. They also have heavy duty spokes and nipples.
A quick lace up just so I could drool...
The process for the rear is almost identical to the front, as you can probably figure out.
So there it is.... all that's left is to get some rotors (6 bolt speed triples for me), bolt them on, and get everything assembled.
USEFUL LINKS:
VXB BEARING COMPANY
MMS & Accessories (metric bolts in fine thread)
RON AYERS MICROFICHE
WHAT YOU NEED:
4) New rims/spokes
5) Tires..
So here we go.
USEFUL LINKS:
VXB BEARING COMPANY
