1 - 4 of 4 Posts
builder in training
okay here is what i found...
my wires:
05 CBR600rr diagram
I have already taken the switch apart and eliminated the horn and high beam wires, and i removed the clutch switch, so whats left looks like:
light blue: right turn signal
light blue/white: hazard? signal return?
orange: left turn signal
orange/white: hazard? signal return?
black: hot
gray: ?
I dont remember if the control has a hazard switch or not. either way, the orange/white and blue/white both go straight to the turn signal and nowhere else. is it safe to splice them in with their respective sold colors? i only have two wires on my turn signals... and what is the gray?!
thoughts?
~Chris
Super Moderator
The wiring diagram doesn't blow up enough for me to read all the text but here's what I came up with:
Light Blue/Wht = Right running light
Orange (red)/Wht = Left running light
Black = Constant power from gauge indicator lights
Blue = Right turn signals
Orange (red) = Left turn signals
Gray = power from turn signal relay(?)
Just as a note of caution, I'm really good with wiring but I'm color-blind so don't take my advice as 100% accurate when I mention a color that's close in shade to another color.
Later, Doug
builder in training
Later, Doug
So far as i know you got all the colors right. That information is very helpful. What do i do with the gray wire? i am not using a turn signal relay, but i do have to incorporate the flasher.
here is what i am mating the control wiring to.
Super Moderator
Going by your diagram here's how I'd connect them.
Harness / Switch
Orange -> Gray {Power}
Brown -> Orange (red) {Left T.S.}
Green -> Light Blue {Right T.S.}
Since you don't have running lights then you could strip out the light blue/wht and orange/wht to help clear up some wiring.
When I swapped controls on my Gsxr with newer pieces some of the wiring didn't make sense so I peeled the wire covering all the way back to the housing so I could trace each function of the wires and trim what I could. On my newer switch I actually gained a hazard switch and flash-to-pass button so that made mine a bit more complicated since I didn't have those on the older switch housing.
Later, Doug
1 - 4 of 4 Posts
