1 - 20 of 27 Posts
Ok... i have a 98 cbr 600 f3 that i have recently turned into a streetfighter. I have this ugly fat wire harness that i need to shorten or completely hide. I need some good wiring advice. on how to do it, what kinda shortcuts there are, and how not to make my head explode while doing it.
· the mad doctor
tuck it under the gas tank. just make sure that you leave the fuse box somewhere relatively easy to access. "just in case"
· Eff Tee Pee
you may have to extend some of the wires if you hide it under the gastank. but it would be worth it when you see how clean it looks.
· Eff Tee Pee
· The Soft Serve Enigma
If you crimp properly it's fine. It can actually make a better connection than soldering and it's easy to disconnect. Depending on the circuit I have also crimp AND soldered, but I usually use simple crimp connectors and if done properly they will last the life of the bike.
· Function IS Form
19 Z900, 88 Kat11
Whatta you mean? Making sure the crimp is crushed all the way and taping it up and everything?
That's usually the problem is people don't crush the crimps, they just squeeze them enough that the wire won't fall out under its own weight.
· Ebay PosterChild
ok thats just not right it never can be better then soldering and why would you want it to be able to disconect it came solid from factory so there is no need to be have the option...unless you are splicing in some kind of a temp wire but then still you should solder it
Yes it can be better than soldering, because if soldering is not done correctly it can overheat the wire and cause it to fail, and it can also trap air in the solder which is a GREAT insulator. As for being solid from the factory, have you ever looked at a bike? Those plugin connectors on the speedo, signals, taillight, etc. They are all crimp-on connectors. The things that are soldered are usually connections onto items like reg/recs and the like. I have done lots of wiring, so has my instructor, and so has my boss and all of us are of the opinion that if a crimp is done correctly, with the proper tools, it will provide a better connection. I've seen it time and time again.
Another point to consider is the ductility of the wire. If you heat the wire and add solder, the solder can "bleed" down into the wire and when it solidifies, it is just that, solid. No ductility. There's a lot of twists and bends on motorcycles, and if that solder breaks, it can damage the circuit and cause issues. Another thing is that MANY MANY people use the wrong type of solder. Most hardware stores sell hundreds of different types of acid-core solder, because it's cheaper but on motorcycles (and other vehicles for that matter) that are open to the elements, acid-core solder easily oxidizes. Acid core is not meant for electrical connections. The only time it should be used is on mechanical connections (ie. attaching a ferrule to a cable). Rosin-core solder should be used on electrical connections.
I have used solder in the past, and on some things it works great, but I prefer proper crimp connections on anything I do, and I'll stand by my electrical work 110%. Do I still heatshrink, of course, but I stay away from solder whenever possible.
I hope that clarifies my stance on the position :D:LolLolLolLol:
PS Haelo posted before I was done this, plugs are still crimped and can easily be disconnected as he stated. If you're breaking a connection that's crimped, sure you'll cut it and lose material. But if you heat a soldered connection, and break it lose, you'll never get rid of all that solder and you can again, destroy the ductility of that wire. Technically if you want to break a soldered connection you should cut that as well and start fresh, same as crimped.
· Eff Tee Pee
i just tie the ends together and zip tie them! :HIJACK:
· Function IS Form
19 Z900, 88 Kat11
Crimping is good for being fast.
I crimped all of my wires when I did my harness last week because I'm lazy and like things that are really quick because I can just redo them if something fucks up.
Doesn't matter if we threadjack, I think this dude disappeared.
lol...maybe he just had something else to do. Just 'cause he's not a postwhore like all of us doesn't mean he's gone forever! lol
1 - 20 of 27 Posts
