I need a little help here guys. I am in desperate need of a triple tree set off of a 91-92 gsxr 750.
Let me know what you got sitting that you are not using.
I am installing the Inverted forks. I have a 93 set here but I did not want to mess with the stops. Do you know if the stem has to be pressed out with the 93 set as well?
Depends on what you are installing the forks onto. I didnt need to swap them because it was direct swap onto my katana, I just ended up with 2 lower triple trees. I couldnt tell you if the stems are different on the standard vs USD gsxr's or not.
I did the fork swap on my 90 750 and used the 91 1100 front end. Direct bolt on with no problems. Go over to gixxer.com and go under the oiler section. There are a bunch of guys over there that should be able to help you out with no problem.
