1 - 14 of 14 Posts
now i took more pictures but i'm dammed if i can find them ..................sooooo
i used the off cuts from the yokes i made
thus tying in the subframe mounts and yokes
drilled them and mocked up the mount area for the subbie
i will turn proper inserts to put threaded ends on the cross tubes
19mm dia 2mm wall tube
i then tacked up the top bit , big flat plate tacked to it while i checked all angles and lengths were central etc
not been idle , the ends of the mounts pulled in a few mm (cos i was stoopid enough to take the alloy bits off ) i should have put the supports further out . little heat and couple of jacking screws and we sorted , weld in 2 wee tubes .
then we weld on the tabs to the frame
next will be fit the plastic
cut a couple of pieces of steel strapping and pop a coupla holes innum
transfer the holes to the seat unit
tap the steel , open the plastic to clearance
then call yer mate who the bike belongs to to come over and we'll weld it in place
at the weekend
1 - 14 of 14 Posts
