21 - 33 of 33 Posts
Discussion Starter · #23 ·
right , more stuff.
set the jig at 700mm, checking with the digital angle finder that both spindles were parrallel
took the fabricated front part outa the bike and clamped it up , i'll tack a temp piece of bar on it to secure it
then put the full hub assembly in place to get some sizes
the hub assembly then taken out and put in the wheel to see if the tube could run straight
not quite
it would have been nice to have the jig big enough to put the wheel in but i have to store it in a small shed , if doing another ssa i might make fittings so i can , but for now i'll make a pair of fittings that replicate the wheel and sprocket , put them on the jig and fit the tubes about them
as it sits now the front and back sections are in place and ready to be joined
Discussion Starter · #24 ·
mounted a gixer rear sprocket on a bitta wood
then mounted it on the jig along with a cardboard cutout wheel
then bend and tacked up a couple of tubes
which fit in here
needs a bit more fitting before welding tho
Discussion Starter · #25 ·
quick update , made it out to the shed about 21.15hr tonight , was a bit bit late but fuck it
basic arm is welded up
let it cool a bit
put it in ,put it in ,put it in ,put it in ,put it in ,
said the actress to the bishop
for the first time in about .................what is it dave ....? 11 month ?
it's on two wheels
it still needs a lot of bracing and its a pretty shit picture , but its 22.45, its dark ,pissing with rain and the shed is full so i hope it'll do for now
i'm pretty pleased so far
Discussion Starter · #26 ·
another bit done started tacking in the bracing
what do we think ?
it still needs more tube between arm and brace , but that'll wait till the chain is on
i'll take the arm out , jig it up and weld tomorrow
Discussion Starter · #31 ·
hellow again , been up to my eyes in getting ready for the tt
got back to this today
started the final bracing , i'll finish these off , get it in the jig and weld it , after that that should be the arm part done
mocked up a temp spacer to hang a chain on too
Discussion Starter · #33 ·
wee update here , while the arm was finished months ago, the bike in question had stalled slightly , enough is enough tho
the arm is in , all spaced up , the rear hub is all finished , caliper mounted, sprocket on , temp chain on , front sprocket made , outrigger plate mate , slave cylinder mounted and i'll have the wheel back on as soon as i fit the torque arm
21 - 33 of 33 Posts
