1 - 20 of 159 Posts
best start at the beginning I guess, the basis for this project is in no way new to me, I've built it on numerous occasions..... I've sold the fuckin thing more times than I care to remember but it keeps coming back, so I figure its time to keep it and build it right. It's the one bike that's never let me down and I've not ridden as much since it last left my hands
some History
as i bought it, in Edinburgh, a long time ago (in a galaxy far far away)
it was ratty as hell, but I at long last had a blade
one day I rode it too work, pulled it apart during the morning break
, painted it at lunch time and built it at home time
skip forwards... a bit of time..... and I get up one morning and chop the back off with an angle grinder
and fit a German seat unit
the seat of which was adorned with the bikes new moniker
(computer coming the cunt so saving before it crashes.... back in 5 )
another TT another tart up
then sold and modified for new owner
then i got it back after the new owner hadn't finished it .....and i started to fit a fairing
thats the potted history of the last .....decade or so ? perhaps longer ...
fast forwards to today
The bike has been reduced to this
I'll blag a newspaper (government propaganda pamflet) tomorrow, this reciept from last nights dinner has a date on it for now
since it's now a keeper it'll need a proper front end and a decent set of wheels ... lets have a look in the front end corner
R1 radial calliper front end .... naaaaaaaahhhhh
CBR1000RR .............
perhaps
or the ZX6R, which I happen to have a matching wheel for
we could have a winner here
what else do i have
digging about a plastic tub under the bench I find a set of Ti headers from a later model Blade, free from friends in a local bike shop years ago, never used as they ain't a straight swap
they weigh about as much as a sparrows fart so i'll be making them fit
this has to go, nothing wrong with it, and nothing against the guy who made it ..... but they're are certain people who will make a big deal over it (long and old story, no need to repeat)
and the rearsets need a bit of tarting up ,
right i'm off to ebay, phone friends etc, few bits n bobs needed, I want the back end in by the weekend
rather than hunt about for bearings that i may or not be able to find .... grab some phos/bronze ...new bushes for swingarm
and they fit just nice too
of course the welded up arm is a bit ugly innit....
soooooo ...... find some paper and loominum
cut a coupla holes with....would you believe.... a holesaw
and glue the new bits in place
t'other side is done too , tomorrow i make the sleeves for inside the bushes
I was sure I had a ZX10r wheel somewhere.... off to the loft for a looky look..... fuckin knew I had one , swapped it for ...something ...with someone....somewhere...sometime ...result
local breakers had a sprocket carrier
my good friend RB donated a caliper and hanger as the blue spot I have is no use for the Kawasaki wheel... thats one I owe him
better finish me cuppa and set about it
made these up today, bushes for the arm and a crush tube
pop one in either side
time to fit the rear caliper hanger , starting by removing the original tether point
and popping some holes in an offcut of aluminium
which gets glued in place
tethering the Kawasaki caliper hanger to the Honda arm
quite handily the standard blade spindle is the right dia for the wheel and the right width for the arm, and the adjuster adaptors i made for the last arm are able to be used too.
pop it all together and see if the original linkage plates will do (stop laughing at the back Seebacher)
yeah, alright, I knew they wouldn't work.....but ya gotta hope
so card templates, transferred to chequer plate mock ups
I'll make a pair tomorow, they can be replaced later if needs be
dug out the seat.....looks a bit worse for wear and will need modified to give a proper shut line around the back of the tank
and i'm guessing there are little brackets available from D'yoo'cati to attach the seat cowl to the seat ?
yoke drawings near done too
as promised, the templates for the linkage plates were transferred to decent aluminium , I need to find the note I made of the standard angle to check if its about right
the gear lever, I had been going to make a new one, or do some machining on the one I already made, but this isn't a big build, lets not get carried away, plenty other people already building far tricker stuff than me in the build off...... so ball nosed slots will be quite sufficient, and match the brake pedal
not that I can complain, for it were I that done it, but I was never fully happy with the rear tank mount, so I cut an aluminium wedge to give a better seat for the rear of the tank
clamped up
and weldimicated
there's a couple of flaws in the wedge, it's a left over piece from a riser , buts lets be honest, i'm not building a space shuttle or fuck all.
wee bit of yoke done... no pics of it .....sorry
rear wheel spacers done tho....with pics
the undercuts in effect turn them into captive spacers, the dust seals keep them in the wheel, much easier when fitting wheel to the arm
I don't like the way a previous custodian mounted mounted the rear master cylinder, bolted on the side of the lever
so I moved it
just needs a couple of wee spacers for around the mounting bolts
arms in, linkage plates on, wheel spaced, caliper mounted, rearsets on
I need a back tyre and a bottom yoke now
todays mantra is "more haste , less speed " time with the machine was limited , must rush ......dumbass
thought top was done .... take it out
oh look....one of the pockets is undersize with no radius edge ....... that'll need setting up again
underside ...all going great right up to the point where i asked too much of an 8mm slot drill
i'll just need to wait till the mill is free again
slow day on the blade today, got a mock up tyre fitted to the rear wheel and went to see my powder coater of choice ......
he found the colour I want for my wheels
what can I say, I'm a child of the 70's, teenager in the 80's .... YELLOW wheels are kool
set up tyre on...... backwards.....not that it matters
just need to hope that between now and Sat I manage a bit of machine time to finish off the bottom yoke .... I really want to see it back on its feet
I was hoping the throttle tube from this ugly as sin quick action throttle would fit in the much smaller and neater standard U.S. fitment honda unit.... no fuckin chance tho, and the other throttle assembly is still attached to the old engine, 6 mile away , ah well, job for another day
not much of an update, but as they say, take care of the pennies and the pounds take care of themselves
needed the spacers for the rear master cylinder, was going to use aluminium, but then I happened across a bit of 16mm marine grade stainless, the exact dia I needed
off to the lathe
fits first time
i'll try for another mini update tomorrow
this will have to have a dry build, with front end in, but I don't want to fit new head bearings in just to knock them out again, soooo....... I made up a couple of nylon facsimiles that'll do the trick for now
then I pulled the UK throttle assembly apart and got the tube out of it
and it fits just fine into the US housing
and if you think that was a minimal update stay tuned for tomorrow ........
the side stand.... I was going to make one, but I can't get away from the feeling that fancy billet stands are just a bit......custom.... rather a contradictory statement i guess, how about ostentatious? so the crappy rusty stand was pulled from the written off donor blade that lies in a corner of a shipping container.
first job being remove the safety switch ...... I mean really..... safety switches ..... I didn't get this fucked up by using safety switches
trust me, once powder coated it'll look fine
tried the stem in the frame with the fake bearings
hey look..... the mill is free, won't be first thing in the morning, better get a shuffle on
underside all done , radii aplenty
top face done too
couple of edges need caressed with a swiss file, but it's getting there
quick try onto the legs
it's a right good fit, well pleased
offer up to frame for a look
I just need to get another half hour machine time to detail the front and drill clamp holes. be on its feet by Sat
like a milling ninja I was , spied the machine was empty, in.... job done... and gone
just the holes to tap, but it's blowin a hoolie out there, inside with a nice coffee seems like a plan stan
try and start the top yoke tomorrow
1 - 20 of 159 Posts
