not a problem at all man, i'm always willing to lend a hand to someone building something thier own. i've been doing it a long time, and i've learned quite alot along the way, figure it's a good thing for me to pass on info and make other people projects easier/better for them.
as for the covers/sliders, check with factorypro. also keep a look out on e-bay, as the old yoshimura covers pop up from time to time too. those ones in particular are nice, they're double thick, and they have that nice yoshimura symbol milled into them .
frame sliders will be pretty generic for your bike, just replace one of the motor mount bolts with a slightly longer one to hold the slider on.
the swingarm sliders are gonna depend on what swingarm you use. if you use the 91 750 arm, you may have to make something work. if you can find (or if it already has) a hollow axle, you can do like i do on my supermoto's, and use big skateboard wheels. just put a piece of threaded rod thru the axle, put the skateboard wheels on the rod, and put a nut on either end to hold it all together. i usually do that on the front axles of my bikes too, since i stunt alot. keeps the fork lowers from getting torn up in a fall.
