Direct Mount Rear Shocks?
9.2K views 22 replies 6 participants last post by  Fathead_03
#1 ·
Hey guys,
What bikes are there with direct mount rear shocks? The style like the 900SS where the shock bolts directly to the swingarm without any linkages, like the picture below. I'm looking to run a direct mount rear shock on my bastard build, it would probably need to the shortest shock I can find that can handle a 350-375 pound bike with a 180 pound rider.
-Mike
Discussion starter · #11 ·
I was actually thinking about using a Buell tuber underslung pull shock on the bastard, but seeing as I'm not doing a full engine cradle, I don't think mounting it to the little engine cradle I'm building will be strong enough. Plus, those pull shocks are fookin expensive from what I've seen.
Discussion starter · #15 ·
there's no fuckin way that a partial cradle would be strong enough to mount underslung unit to anyhow. i would ditch that idea all together because you'll stress your upper mounts so much
That's what I was thinking too. I never was too serious about that option from the start because of the high prices.
Discussion starter · #17 ·
I really would like some more pictures of a TLR/TLS shock setup with the dampener removed. I think that could be a trick setup. I get how it works, but I'd like some ballpark figures of linkage lengths and shit. Maybe spring rate.
Don't factories usually have their stock shocks sprung for like 200+ lb riders? So I'm guessing the TLR shock has a 5" spring and a spring rate between 800 and 850 lb/in. That might be a decent shock for my project too. It looks like a pretty short shock, about 9.5"-10" from eyelet to eyelet.
Discussion starter · #19 ·
Keep in mind, that whats there is just a spring. No dampening. The shock portion was a dampener that was attached to that crap. That was merely a "spring on a stick" as they call it.
Damn, that sucks. :( If it had a dampener in the shock it would have been almost the perfect shock for my build. Hopefully I can find one that about the same length as that with a similar spring rate.
