21 - 40 of 62 Posts
Discussion starter · #22 ·
dude. I am so jealous. I've always wanted to build something like that, the countries I've lived in so far make it difficult and very expensive to achieve.
I now understand your username :D
I'd encourage you to build it! If you have the inspiration, don't let a few details get in the way. When I started the project I was living in a small apartment with no garage and only a box of hand tools.... but I knew had to build this. I just figured things out as I went and acquired tools and equipment when ever good deals would pop up.
I agree that cost is the universal hurdle that we all most face, but sometimes it just takes some social engineering. My forkless bike could not have been built if not for a few good friends I met along the way who understood my passion and were very supportive with their own time and resources. This forum is a fantastic place to find like minded people with every imaginable skill and resource, and most are very willing to help out.
Amazingly good looking work - looks like it rolled out the Bimmota race shop, and better than a lot of the Elf bikes I;ve seen pictures of.
Is that hub-center steered, or is the axle supported by a steered upright?
Nice to know a pencil-and-paper design can work out, that's what my Hossak has ending up as. Looks like I may be a bit ambitious thinking I can get it done in a single winter, as my first ever bike project... we'll see. I'm taking a lot of shortcuts (no custom frame) and am not ashamed to be seen on a rat bike, so maybe its do-able...
Discussion starter · #24 ·
Thanks for the compliments! Much appreciated... I often made parts harder than they needed to be just to get a "factory" look.
The axle is supported by the steered upright, so technically not a "hub center" design. That said, I do have a true hub-center project that I might get to someday after I finish a bunch of other halfway started projects:doh:
Nothing wrong with a rat bike, especially to test some ideas. If it works well, you can always take what you learn about the design and do a phase-II re-build with nicer parts... or if you're like me you'll satisfy your design curiosity and move on to something big, better, or different. Its all good!
Finally by my junior year studying transportation design I got an opportunity to build a prototype of what I had been reading about.
An advanced product design class got to have Yamaha as a corporate sponsor for one semester.
My "Recon" off-road scooter concept was designed and fabricated in 14 weeks.
ACCD?
Yep... seams like a lifetime ago.
Very cool! This is the last place I figured Id run into a fellow Art Center Alumnist! Most designers I know are so prissy they wouldn't be caught dead on a streetfighter forum! I only graduated 2 years ago and it seems like a lifetime for me as well!
Very cool and inspirational work you've got here man! Lookin' forward to watching this come together!
Discussion starter · #29 ·
I now have about a month to get the bike cleaned up and re-assembled. I'll follow the same order as the original build and try to recount some of the original design and construction process.
With the basic front end design on paper (literally, as I didn't own a computer at the time) I decided to start with one of the most difficult parts to produce... the front wheel. As I've mentioned before, I really wanted this bike to look like a factory concept and not garage built. With this in mind, I would need front and rear wheels to match. I would also need a modular constructed wheels so that I could use an existing rim mounted to a custom machined spider (center) for the front wheel. Turns out Kosman Specialties makes (or was making at the time) some nice drag racing wheels that looked good and were a modular construction. The bonus was that their shop was only a few blocks from where I was working.
The rear wheel is semi-custom in that they machine the hubs to fit a sprocket and rotor to my specs. Then they supplied a blank front rim to match the rear. So all I had to do was get the front spider machined. That should be easy, right?
The front spider started as an 80 lb block of solid 6061-T6. I found a local machine shop with a large enough lathe to turn the profile. Bob, the machinist and son of the owner would later become a good friend and ended up making most of the first machined parts on the bike.
With his machining skills the square block of aluminum slowly became what looked like a big silver salad bowl. Next was to get the spoke pattern cut out... so back to Kosman.
Turns out in spite of the all the custom work they were doing, for some reason they didn't want to do the front wheel, but instead referred me directly to the shop that was doing their CNC work. A few weeks later I had a spider and with the Akront rim attached had my front wheel done!
Pictures should be self-explanatory....
Discussion starter · #30 ·
Ya, now you got me laughing... unfortunately so freak'n true about the attitudes:doh:
Are you also a Trans major? I found I'm more suited to product design with my engineering background, but obviously still designing and building motos on my own.
Thanks for the props. much appreciated.
Very nice, have always been fascinated with Hossak, Foale, Saxon etc. Just like to see someone trying to find a alternative to telescopic forks (not that I have an issue with them, just the thought that there maybe something better out there)
Was it pretty good from the start or is this version 10 or more?
Oh and whoever thinks this would look better as a streetfighter should hold their head in shame, stupid fucking suggestion!
Discussion starter · #32 ·
Only one version... what you see is how it was originally designed and built. Its not perfect and there are a few individual parts that could be refined. I have a new design (in CAD) for the wheels that will make them lighter and more modern looking. But if I were to build a second version there is very little I would change in terms of the overall design.
That said, I would like to build a double-sided front swingarm design (true hub-center design) similar to a TESI/Vyrus design.
I should also mention in regards to how well the bike works... when it was finally running and I was doing some track testing, I let a more experienced racer take it out for a few practice laps (Buttonwillow Raceway) and his lap times would have been good enough to put him on the podium in the 450 Superbike class. He really liked the way the bike worked, with possible exception of the front brakes which maybe work a bit too well (tend to be a bit grabby).
I did a lot of homework with the design of this bike... but also probably just got lucky with some of it.
Discussion starter · #33 ·
I'm now starting to put the bike back together. Frame and both sub-frames have been painted in Champagne metallic. Eventually I will powdercoat the frame, but since I wasn't sure if I'd like this color with the new overall color scheme, I decided to do it with rattle cans. Turned out okay, but not great.
Many people think I used a stock RZ350 frame, but that is not the case. The frame is scratch built using two hoops. The rear swigarm gussets and the engine mount brackets were used from a RZ frame thus causing the confusion as the swingarm gussets are very recognizable. Here are detail pics of the RZ brackets and other brackets on the frame that were scratch build for this bike.
Also had a few bits re-plated in bright zinc. Goal is to have a "factory production" look as opposed to a custom look so nothing fancy with the plating.
Here is the front swingarm. It is made from three castings connected by sheet sections. The castings are hollow and have internal ribs and bosses for suspension bearings. They are very complex on the inside. At a later time I'll try to post pics of the match-boards and core-boxes that were used for making the castings. The one thing that did not go as planned was cleaning the original part. Rather than have it chemically cleaned, I mistakenly had it vibratory cleaned which removed too much of the casting texture and thus it doesn't match the factory Yamaha swingarm on the rear. I have some spares, so someday I'll have another one done correctly for the "factory" look.
A few notes since someone will ask... I did not do the welding on the aluminum parts. I have a guy who is fantastic with welding aluminum, so he gets all my aluminum work. (I just did the crappy welds on the steel parts). "A-N-D Vehicles" logo was imbedded into the match-board casting tool using a zinc plate etching. This was the name of my company from a long time ago.
It is now less than a week before I leave for Portland, so I'll be in a panic to get the bike together this weekend, so not sure if I'll get more photos of the progress... but stay tuned!
This is the cool stuff you do in your spare time. That way you actually get to keep it.
Discussion starter · #38 ·
+1 what blensen said! Not only do you get to keep what you do on your own, but your engineering skills give you knowledge and exposure to manufacturing methods. Also, become an expert in the materials and processes you use to make your motorcycle projects successful and it will help your engineering career. Its a win-win situation.
This thread is so full of awesome a little bit just dribbled out on the kitchen floor.
Reactions: Ahks
Discussion starter · #40 ·
Last week I got the bodywork back form the painter. I had decided to go with a color scheme similar to the original 1985 colors rather that something original. The idea being that I want a factory look. Logos are from RDdecals.com.
The tank is stock RZ500. The tail is custom made starting with a Ducati 916 race replica, then completely reshaping the tail. Tail light in-set is for a Honda F3 tailight (mounted upside down). Front fender started as Honda F2, but then modified to fit my steering upright. Rear fender is 100% custom made. Windscreen started as an aftermarket for Kawasaki Z1000, then duplicated in fiberglass and heavily modified.
the seat foam was shaped in 1/4" and 1/2". Started with paper patterns transferred to the back of the foam. The foam was then rough cut on a band saw and final shaped on disc sander with a very minimal hand sanding to smooth out a few places and clean up the scruff on the edges.
Here are the control rods for steering now re-painted ready for assembly.
the control rods connect via a bell-crank assembly under the tank. Large holes in the bracket allow access of throttle cables and tach cable.
The disc brake carrier was one of the first parts I made. It is machined from a solid chunk of 6061. Rotors are early FZR1000. The rotors float on stainless barrels.
The front axle is fabricated using 4140 (chro-moly). the drive pins are from the back hub of a Honda (NT650) Hawk).
The front caliper is an automotive unit from Performance Machine (Roland Sands dad's company). These have been modified with center spacers that support a floating center pad (double-sided). The ugly grey portion is a heat-sink for the center pad assembly.
The A-arm is fabricated from two CNC machined rails, some thin sheet welded to create the webbed area, and machined block at the front to accept a 12mm ball rod-end.
The front up-right is mainly a sand-casting with a thin sheet welded over the top. There are rib details not visible. I made the wood match-boards used for the casting process. The ball joint is from a Yamaha GTS1000.
Front-end cleaned up and coming together...
The bike is almost completely re-assembled, but this is all I have pictures of right now. Wednesday I leave for Portland and my destination at The One Motorcycle Show this weekend. I'll post more pictures when I return. I'll also try to get photos of the match-boards and core boxes used for the castings as well as some of the raw castings (I had many extra parts made).
21 - 40 of 62 Posts
