Is fiberglass strong enough to hold a seat?
3.5K views 10 replies 9 participants last post by  Bskicrash1
#1 ·
I'm going to glass a tail for my subframe...
This will be my first glass job... but, I have the confidence that I'll do it just fine.
My question...after I glass my tail, and place my newly created seat on top of the glassed tail... will the fiberglass crack under my weight? I weigh 180 with all gear...
thanks
#9 ·
Are you building it off the bike and then mounting it by slipping it over the subframe? I'd be as worried about it cracking during installation if any bending/prying is necessary to fit it.
My stock subframe and many others have a brace that is raised up off the frame and fits under the plastic right between both seats if you need support.
#7 ·
I agree with post #3 - - you can surely reinforce the fiberglass with strips of wood. The surfboard I had in the 80's had stringers glassed into it; it was plenty strong. Good luck with your project.
#10 ·
The strength is just gonna depend on how you design it. I built a little fiberglass/honeycomb beam in my engineering intro class that was 1.5 inch thick but supported 4500 lbs pushing in the center over a one foot gap.
Are you building the tail and the seat as one piece? If you do that you will have to do what chandler said and glue foam or a cover on there. If you make the seat a separate piece, then you can actually wrap a seat cover around it.
