The crash was me being an idiot and going off a 20-30 ft embankment after locking my brakes twice on a unexpected sharpening turn and the bike tumbled down hitting upside down on the handlebars, the rear, and the exhaust. I walked away just fine and got extremely lucky.
Here is how the bike looked before the crash.
Here it is after.
Gauges destroyed, handlebars bent, something broken inside one of the forks causing the wheel to point to the right, and the clutch cable threaded tube going into the lever even snapped in half. The rear plastics were just about all destroyed. Headers were bent and exhaust nearly broken in half. Engine side cover has some scrapes and the gas tank is dented.
I'm new at working on motorcycles so I'm learning as I go, input is welcome.
I also have a 1982 KZ1000 police bike street tracker that I'm working on at the same time (my current daily driver since crashing my SV650).
Pictures
Build Thread
On to the fun!
That day I stripped it down to this to make sure everything structural is fine. The frame, subframe, and rear sets were undamaged in the crash. It started right up once I hooked up the disconnected clutch lever sensor.
Now that I know it's good I make a plan.
I emailed R&R racing and they can provide a square tube subframe without the exhaust hanger or fairing mounts. This should allow me to use my stock mounting Sargent seat that survived the crash.
Time to start buying stuff.
04-05 GSX-R 1000 upper triple clamp
2006-2007 GSXR 750 front end
2007-2008 GSXR 1000 front wheel
Remove the subframe and battery box plastics
Test mount forks, top triple, and wheel. They fit (what a relief)!
The ignition doesn't clear the frame, easy fix using a dremel on the mounting holes.
Test fit all the brakes and controls. Surprisingly I have full motion without the clip-ons pinching my fingers against the frame.
Ordered some cheap used stock headers and spent a few hours making them shiny. I went over it with wire wheels, sand paper, metal files, and polishing wheel with Simichrome. I cleaned up the welds and removed spatter. I soaked the rusty hardware in white vinegar for a few days.
Delkevic 200mm carbon exhaust.
Mounted with the shiny headers. Can see where I tore off the head of a rusty bolt holding the front header pipe to the engine, may need to drill it out and tap it. It's only loosely held on by one bolt for now.
I will likely shorten the exhaust down-pipe a little but for now it works and should hold just fine without the exhaust hanger.
I'm now waiting on the subframe so I can fabricate an under-tail to mount an antigravity battery and all the electronics. I'm also deciding on a headlight.
More to come soon...
Here it is after.
Pictures
Build Thread
On to the fun!
