Fork length Compilation
79K views 24 replies 13 participants last post by  Steppin Razor
#1 ·
I thought i can share that with you, it can help a lot of people here..
Its the compilation of fork lenght i did this winter for my project bike.
Feel free to comment on it to add other bikes or correct informations. i'll update it as informations comes. i want to add tripple tree spec (up and low diameter, offset and spacing) as soon as i find away to convert my excel spreadsheet to txt without having to redo the layout...
Make/Model year Range Fork Length mm (inch) (axle center to fork cap top extended suspension)
Buell
M1 700mm (27,5'')
M2 730mm (28,75'')
Ducati
998s ohlins 720mm (28,374'')
monster 750ie 02 730mm (28,74'')
st3 04-05 725mm (28,54'')
st4s 02-03 697mm (27,44'')
Harley Davidson
most 812mm (32'')
Honda
CBR1000RR 692mm (27,25'')
CBR600F1 87-90 738mm (29,05'')
CBR929 00-01 724mm (28,5'')
CBR954 02-05 724mm (28,5'')
F3/F4 780mm
RC51 SP1 762MM (30'')
RC51 SP2 736MM (28,97'')
vfr 750 fl 791mm (31,15'')
VFR800 780mm (30,75'')
vtr1000f 778mm (30,62'')
kawasaki
versys 774mm (30,5'')
ZRX1100 766mm (30,15'')
ZX10R 06-07 743mm (29,25'')
ZX10R 04-05 730mm (28,75'')
ZX14 742mm (29,25'')
ZX636 750mm (29,5'')
ZX9r B4 94-97 766mm (30,15'')
Suzuki
GSF 400 JDM 820mm (32'')
GSXR1000 01-02 726mm (28,54'')
GSXR1000 03-04 720mm (28,34'')
GSXR1000 05-06 720mm (28,34'')
GSXR1000 07-08 720mm (28,34'')
GSXR1100W 94 770mm mm (30,25)
Gsxr1300 Hayabusa 99-07 725mm (28,54'')
Gsxr1300 Hayabusa 08
GSXR600 00-03
GSXR600 04-05 720mm (28,34'')
GSXR600 06-07 738mm (29,05'')
GSXR750 90-95 750mm (29,5'') 257mm (10 1/8'')
GSXR750 00-03
GSXR750 04-05 720mm (28,34'')
GSXR750 06-07 738mm (29,05'')
GSXR750 SRAD 96-99 730mm (28,75'')
RF600 97 750mm (29,5'') 257mm (10 1/8'')
TL1000R all 717mm (28,22'')
TL1000S all 732mm (28,81'')
VZ800 Marauder 838mm (33'')
Yamaha
FZR400 790mm(31.1'')
FZ750 1986 825mm (32,5'')
FZR1000 87-88 770mm (30,3'')
FZR1000 exup 89 770mm (30,25'')
XV920 J virago 82-83 825mm (32,5'')
fz1 2007 762mm (30'')
To add specs or correct some existing specs please send a PM
Base on informations Gathers around the net, always confirm specs by your self.
#8 ·
Re: Fork Lengths
'twould be neat to have. I can throw some up....later.
MAKE SURE: you get sprung and un-sprung from center of the axle to the top of the clamping area :metal:
#9 ·
Re: Fork Lengths
I am needing some of this info as well. My Bandit needs some new front legs. Up and coming project soon.
#11 ·
Re: Fork Lengths
link? I'll merge them or delete this one if there is.
#23 ·
If a mod wants to add to the first post...
CBR600 F3 and F4 forks are both 41mm tubes and 780mm long from axle centerline to top of tube. RSU, of course.
A little added info for anyone entertaining F2/F3 forks. 1991-93 F2 forks are damper rod, but the 1994 F2 fork is a cartridge fork ( rebound and preload external adjustment only). The 1995-98 F3 forks are all cartridge forks. Again, rebound and preload external adjustment only.
