81 - 100 of 190 Posts
Discussion starter · #81 ·
Ok i need some help. I need adapters made to slip into a 25mm bearing for a 19mm axle dimensions are...
all measurements are in millimeter
OD 25 (.983")
ID 19.05 (.751")
Total length 29 (1.14"
Length to shoulder 25 (.984")
shoulder 4 (.16")
Shoulder OD 33 (1.3")
OD 25 (.983")
ID 19.05 (.751")
shoulder 4 (.16")
What material? I can do this, but honestly, it'd probably a while before I could get it knocked out.
Discussion starter · #85 ·
Discussion starter · #94 ·
Updates.
Steering damper from an R1 with help from the bracket from a TL i welded it to the neck
Metric clutch Lever and perch. Just heated up the perch bent it out and with a 1" pipe bent it around to fit. And with a dremel and a drill modified the levers to fit the harley clutch cable.
That's a cool looking light any more details ? Looks like a lot of wiring to hide tho. Looks cool m8
Discussion starter · #99 ·
Finally got the green light for my spoked front wheel. 3.5x17 aluminum 40 spoke to match my 4.5" x 17 rear. I will repaint her flat black. I'm going hotrod. Black flames. Red or chrome rims With white wall tires. Bridgestone BT 021 Battlax with a special designed white wall coating. I'll post pics once I start again.
